Finally have a belly pan option!!!
RGPIII
Bridgeville
DE
Does it have the replaceable absorbent mat
RGPIII
RGPIII
Bridgeville
DE
New item we are releasing for sale in conjunction with Sumit Goyal from 1320Tunes. Engine and transmission containment pans for the charger, challenger platform. A great alternative to engine/transmission diapers. We utilized 6 factory mounting locations for easy installation and removal for maintenance. Made from. 090 aluminum for strength and scatter resistances. Full pan will have removable pigmat layers, push pins to keep the mat in place, sealing washers, and all necessary hardware. Engine pan can be used as a stand alone piece. High sides for maximum splash containment, and can be used with the front most factory splash guard. This is a must have for many sanctioned events MSHS, TX2K, SCT etc. We have several more picture if you would like we are forward of the balancer and rear of the engine block.
Engine pan capacity at it lowest point comes in at 11qts and weighs in at 7.7lbs
Transmission pan capacity at it lowest point is 7.84qts and weighs in at 4.1lbs
We are releasing pricing at 399 for engine, 299 for the transmission (if purchased later on) or 649 for engine and trans pans together. Plus shipping. Please reach out to Sumit or I directly to place your order. Dealers welcome!!
Saw these yesterday. Look pretty good
RGPIII
RGPIII
Bridgeville
DE
yup you know mines already reserved.
Looks spiffy.
This is a good one for a wide ranging topic of discussion. Promoters who put on events, want to complete those events. For both spectators and racers. Sometimes they end up running so long that they don’t even get to the class finals due to the number of cleanups from oil downs. Other times I’ve seen them run until 3am. A long boring day for everybody with money wasted. I’ve been to a couple where that happened. Consequently they are starting to require a diaper or containment device like this to be allowed to race. I believe MSHS is one of those. There are upsides and downsides to both. The pan like this is primarily to keep oil off the track when the car slows down or comes to a stop. I’m not going to downplay that. That saves the race from also coming to a stop. And with the way things are going, if you have a nine second car and want to run at any of those events…. You will be getting one of these or a diaper. A big question is…. How much oil gets out of a pan like this at speed and onto the rear tires, possibly resulting in a loss of control. I don’t know. I will imagine it could help with the absorbent material in place and depending on circumstances. A couple issues with a pan like this though is it’s not going to keep oil off the headers, where the fire starts (now contained in a pan under the engine). The upside with the diaper is it is made out of what they are calling a ballistic material that is supposed to contain the hard stuff preceding the oil. It is also lined with the absorbent stuff to keep the oil inside and very little if any is going to get out. Downside to the diaper is changing the oil. The drain plug in the stock front sump oil pan is covered by the diaper and is impossible to get at without basically removing the diaper. Doing that without a lift isn’t something I would want to deal with. I’m using a diaper, but I have a rear sump oil pan and changing oil by simply pulling the diaper away from the drain plug is easy. One last thing while on the safety part of this….. carry a real fire extinguisher your car. It could save your car. Really! 83AB96C4-CAC2-4ADE-A45D-E9AB888FC6AA.jpeg
Kevin Smith built one for mullet a few years ago with the absorbent pad inside. Allegedly it worked pretty good.
Don't know if they're still running it with the engine upgrades.
Hatermkr
West bend
2016 helldemon
Would not work with my trans jon become a dealer
I'd have to figure out if this would work with mine as well. Mount points changed.
Hatermkr
West bend
2016 helldemon
I would have to find a dealer if I wanted one.
RGPIII
RGPIII
Bridgeville
DE
You both have hellcats? what has changed on the mounting locations for the factory splash shields?
Hatermkr
West bend
2016 helldemon
I have a deep oil pan and trans pan.
I have a th400 and different mount locations.
RGPIII
RGPIII
Bridgeville
DE
Just my opinion, but… if you have a racecar with a 400, you should have the diaper. It gives you containment all the way up the sides of the block and nothing gets out to get on the tires or start a fire. Mine…. 2CB5B3E5-64B3-4058-8070-DFD6812F91DA.jpeg 763FC7CD-D7C2-40A9-9237-955A6B67C45F.jpeg 390AAC05-AC00-45E8-AA3A-F72F9EC069C6.jpeg
Suwanee
It’s a 2 piece part. We do plan to customize one for turbo cars.
I do have the access to TH400 and see how we can make it work
Hell yeah! Now I don’t have to fix my oil leak 💪💪💪
Trackhawk, RS3, Golf R
