Mickey Thompson P305/35R20 ET Street S/S Tires - pair
Trader history for droptopp (0)
droptopp
Rochester
Mickey Thompson P305/35R20 ET Street S/S Tire (3402) 90000024578
Brand new in boxes - never mounted.
$700 - Rochester NY - pick up only.
Part number : 90000024578
Weight: 34.00 LBS
Min. Wheel Width: 10.00in.
Max. Wheel Width: 12.00in.
Black Sidewall
Directional Tread Design
Tire Size: P305/35R20
Specifications:
Section Width 305
Aspect Ratio 35
Tire Diameter (in.) 28.7
Wheel Diameter 20
Tire Size 305/35-20
DOT-Approved Yes
Tread Width (in.) 10.98
Tread Depth (in.) 6/32
Speed Rating N/A
Maximum Recommended Wheel Width 12 in (304.8 mm)
Minimum Recommended Wheel Width 10 in (254 mm)
Maximum Tire Diameter 28.99 in (736.346 mm)
Minimum Tire Diameter 28 in (711.2 mm)
Manufacturer's Part Number: 90000024578
Rochester
These still available? I’m in Roc
droptopp
droptopp
Rochester
Yep, also have a new set mounted on wider PK Hell raiser 5 star rims.
Let me know.
Rochester
Let me know.
I’ll take them. I had the pk setup on my narrow body. Going wb now, so I just need the tires. Which local cat was yours btw?
droptopp
droptopp
Rochester
I had a 2017 white charger for a long time but it was stolen in Feb. Also have a built GTR and an NSX. Waiting to replace the hellcat until the market gets back to normal.
I shot you a PM with my number.
