Push Starter Button Not Enabling The Starter Motor To Engage. Advice Please
Lord Hellcat
Lord Hellcat
Barking
United Kingdom
Thread Starter #21
Can you shut the car off via the button after doing this?
I took it as referring to the park sense system which is unrelated to the trans. There's also the "Transmission not in park" message that would mean what you're saying. That message would come up when trying to start the car if it wasn't in park or the park gear release lever was pulled up.
yes it is an A8 and the car does know that it is in park. The button works as you would expect save churning the starter motor.
Lord Hellcat
Lord Hellcat
Barking
United Kingdom
Thread Starter #22
@Lord Hellcat is your PCM flashed to an aftermarket tune? If so, I am sure you have tried, but re-flash it??
yes we also re-flashed the tune as well just in case
Lord Hellcat
Lord Hellcat
Barking
United Kingdom
Thread Starter #23
So this would be the fuse to pull to prevent theft when parked?
yes, that would work really well unless someone knew what they were looking for.
There are 7 relays in the fuse board that are all the same so they could take one out of another slot and use it but they would have to be very clued up
stonewall
Conway
AR
2017 Dodge Hellcat Challenger
Dead Battery's seems to open a can of worms with these things. Mine died and then the AC would not turn on afterwards. In mine it blew a relay, I assume from a voltage spike when the battery was re connected. Good luck with this, and please let us know what it takes to fix it.
Lord Hellcat
Lord Hellcat
Barking
United Kingdom
Thread Starter #25
Yep, I don't think it helped sitting idle for nearly 10 months. I keep a CTek charger attached but the battery still failed, well it is 10 years old. Liam is popping over to check the readings on the RF hub with regards to brake switch and key etc. Rest assured I will keep you all in the loop. It was great taking the car out for a spin yesterday. I had forgotten just how bloody brilliant these Hellcats are :)
Lilschmied
Nowhereville
Stupid question, did you check the 30a fuse in line after the relay?
Lord Hellcat
Lord Hellcat
Barking
United Kingdom
Thread Starter #27
yes, all fuses in the fuse board both in the engine bay and the trunk were checked
Lord Hellcat
Lord Hellcat
Barking
United Kingdom
Thread Starter #28
So Liam popped over last night and carried out some more tests.
Using a snapon diagnostic tool we found that the RF Hub shows that when the car is in drive it agrees with this.
In neutral it just shows ????
Reverse shows neutral and Park shows as reverse.
If the diagnostic tool is not giving us false information then this might be the problem.
The RF Hub will not allow the starter motor to engage as it thinks the car is in reverse.
If anyone has a 15 to 17 Hellcat and a snap on diagnostic tool that they could plug in and see what their RF Hub readings are that would be very useful as a comparison.
We ran out of time to do some more testing at the relay end
Shifter handle "jiggle" test make any difference???
Lord Hellcat
Lord Hellcat
Barking
United Kingdom
Thread Starter #30
no difference Bull. All the other ecu's like ABS, transmission all see the correct shift position. It is just the RF Hub that goes one shift out
Lilschmied
Nowhereville
Unfortunately my car is too new. I took a look anyhow but I don't see the gear select anywhere on the module, just a park status.
Anything else screwy at the rfhub? It's got lots of inputs and outputs to look at. Since everything communicates via canbus I'd be suspicious if the only weird reading was the gear select.
Hi @Lord Hellcat nice to see you on the forum, sorry it's for a problem.
Does the RF show any codes?
Did Liam install the system?
~Linda
Lord Hellcat
Lord Hellcat
Barking
United Kingdom
Thread Starter #33
Thanks for taking a look. I should have mentioned the only way to achieve the test is to pull out the gear lever pin so that you have have ignition on and then you can cycle through the gear selection. Of course with the pin still in you cannot take the vehicle out of park without the engine running
Lord Hellcat
Lord Hellcat
Barking
United Kingdom
Thread Starter #34
~Linda
Hi Linda, I hope you and the family have been keeping well. Good to hear from you :)
Liam installed the pulley, injectors, PCM etc a couple of years back and came with me to the dyno shop to install the remote tune that Josh did for us.
So he is very familiar with the Hellcat.
The only fault code we have is P0601. We had this code back when we fitted the unlocked PCM and I questioned Josh at the time if this code would go once we did the tune.
Neither of us can remember what the outcome was as I think we spoke to Josh on the phone about it rather than email.
Still waiting on Liam coming back round to test if we are getting power to the start relay when we cycle through the gears
@Lord Hellcat, thank you we are doing well, and keeping busy as usual. I take other than your Hellcat you and your wife are also doing well.
Maybe this was posted already. Have you used the FOB to push the start button?
If that works, that is good, but either way because you lost battery, your Hellcat may have to go through a couple of run cycles to get everything back online.
Sometimes with the battery loss, different modules will store some codes, and your Hellcat might just need to go through some run cycles.
I also asked Josh about that fault code, and he said that one you can just turn it off.
~Linda
Lord Hellcat
Lord Hellcat
Barking
United Kingdom
Thread Starter #36
I am very pleased for you Linda. Glad everything is okay.
I did try the FOB to push the start button and no joy, also the remote start function will not work either.
Thanks for speaking to Josh, that is also very helpful.
We will keep trying to find a fix :)
stonewall
Conway
AR
Did you ever get this thing fixed?
2025 Dodge Durango R/T Plus
yes, button works as normal and shuts the engine off. Something has caused the breakdown in communication between the push button and the starter motor.
Possibly a body control motor. Just hoped someone on here might have experienced the same issue
My charger does the same thing. Only happens after it runs about 45 min and you try and restart. Just doesn't crank. Then after about 30 min it will start normally. Very annoying. Happens 8 out of 10 times. Very annoying.
Lord Hellcat
Lord Hellcat
Barking
United Kingdom
Thread Starter #40
Hi everyone. Thank you for all your collective thoughts, ideas and wisdom.
So we finally got to the bottom of the issue.
Basically the route cause of the problem turned out to be an immobiliser that no one knew or remembered being fitted.
Liam sussed it out after taking the glove box out and looking at the wiring loom behind. Whilst sitting around waiting for us to fix the supercharger issue the immobiliser unit had died.
Immobiliser now bypassed and all working perfectly again thankfully :)
