Restriction To Order Redeye Parts Now Lifted
Keswick
2018 Challenger SRT Hellcat
Just wanted to pass it along that the restriction to order Redeye parts is now lifted. Obviously the restriction remains for Demon parts.
First stop driveshaft .
Stay safe everyone!
I had that drive shaft. It's not worth it.
Tae1974
Keswick
It’s stronger than the one I have and better than vibration so I will take it.
As someone that has a one piece DSS using the new system which is a direct fit, zero vibration, but hey your dollars.
Tae1974
Keswick
Well you are one of the lucky ones then. That’s awesome.
RedEye19FL
Bradenton
2019 TorRed Challenger RedEye
Go for it Tara! Incidentally, you need to change your flag to Canadian on your avatar!
I for one really like the redeye driveshaft . It's more then strong enough for anything we will throw at it . I had nothing but issues with aftermarket driveshafts . 5 different driveshafts from 3 different companies.
Tae1974
Keswick
I can’t figure it out lol!! I’ve sent them a message. All my settings are Canadian so not sure why it says USA.
2fast4u
Edwardsburg
It is working, I see Canadian flag on your avatar.
Tae1974
Keswick
Awesome thank you!!
The flag is assigned based on your IP address, so for example, if you're using a VPN based on an address elsewhere, you get that flag...
<---Such as this?
Usually when I'm on my VPN, I get an Italian flag, not this time though
Tae1974
Keswick
Thread Starter #13
Ah ok work pc is out of Pittsburgh so that makes sense. Thank you
QUOTE]
I should get a VPN server on the moon .
That blow everyone's minds !
Tae1974
Keswick
what company you work for based out of Pittsburgh?
I’m actually in Ontario Canada but our server is out of Pittsburgh with head office. Wesco Utility.
My CCI isn't bad at all...
Every 1 piece will amplify noise. By design. Just a matter of how much.
I'd rather my driveshaft not explode though. So I live with it.
The new new NEW DSS might catch an eye later...but this CCI is smooth as glass and built like a tank with joints I can get at Vatozone if I need them same day. Cant say that about the others.
Wonder what dodge did for the charger redeye? It'll need to be longer to fit our cars but that would also mean thicker, larger or stronger material somewhere to maintain critical speed at that length.
This is the one I have and since they moved to a direct fit instead of the yoke/adapter all the vibrations/noises are no mas!
Stay safe everyone!
Didn't know there was on Redeye parts:unsure:
Tae1974
Keswick
Thread Starter #19
Yes here in Canada we couldn’t order.
Flag :unsure:...oh yeah...I didn't get that far,,:giggle::giggle::giggle:
