Vibration / wobble at a very slow accelartion
Belgrade
MT
2022 Challenger RE
This started after about 8400 miles, car is all stock and is a 2022 Challenger RE.
From about 30 mph though 80 mph. If I do a very slow acceleration, I can feel a wobble / vibration in the floor board / coming from the front of the car. My wife in the passenger seat can feel it to, and she typically doesn't notice anything. Also notice it when reversing; this is when I first noticed something was off, during a reverse.
It's really noticeable from 40 mph on.
Again, it's only on a very, very slight acceleration but the wobble/vibration is very distinct. Cruising at a constant speed car is fine; can't feel any vibration with a slightly harder acceleration.
Dealer said it almost seems the tranny is struggling to find the correct gear. Dealer put the car on a lift, felt the drive line and dealer didn't like what they were feeling. Dealer installed a new drive line (exactly what work order said); it was warrantied. But vibration is still there so car is back at the shop.
Any suggestions? It is not tires / wheels.
Wheels stock?
B
Belgrade
MT
2022 Challenger RE
Yes. Dealer checked balancing before they installed a new drive line.
What do you mean installed a new driveline? Driveshaft?
They usually call it a propeller shaft
B
Belgrade
MT
2022 Challenger RE
Work order says: installed a new drive line
I'll have to ask what this means specifically.
edit: I just googled: installed new driveline 16300101...I should have put the number on my OG post
And a document came up. I would post the link, but when I click on a link a doc comes up, see attached.
B
Belgrade
MT
2022 Challenger RE
Yep; my bad I didn't put the code from the work order as this is what they did. Put in a new propeller shaft.
Edit: Should work order have said replace propeller shaft instead? As would this be a drive line https://www.dcperformance.com/p-redeye-driveline-kit-77072540ab
I'm no mechanic, but drive line and propeller shaft replacements look to be quite a bit of difference.
If they have ruled out those issues...replacing transmission is next...they wont service it...just replace it
45-70govt
Ghetto
Unless direct drive, then no propeller shaft ;)
Our cars are often described as boats!!!
There’s no way they replaced the driveshaft, diff, and axels. Should have a part number indicating what they replaced
When did it start??? Before or after the "driveline" repair???
B
bobn
Belgrade
MT
2022 Challenger RE
Thread Starter #13
My post #6 shows what they did.
The wobble/vibration started at about 8400 miles. Which prompted the propellar shaft replacement.
