GForce Engineering fully-fabricated 9” IRS With modified cradle
Well the car is “done”, other than an alignment, so it is just a matter of waiting for the good weather to hopefully show up in a couple of months.
In the meantime I decided to go ahead with a mezzanine project I have wanted to do since we moved here about 2 1/2 years ago. We live in a barndominium style home that was built in 2020 and although it was framed in during construction, there wasn’t an entrance to the shop from the second floor, which is our main living area, so I decided to go ahead and finish it.
So although this isn’t a post about the car it is the car’s place.
View attachment 177893 View attachment 177894 View attachment 177895 View attachment 177896 View attachment 177897 View attachment 177898 View attachment 177900
Awesome garage...who's the rocking chair for...gramma ???
Ta2ude
Fuck Carney
2019 Redeye Widebody Challenger
Thread Starter #102
Thanks
The rocking chair was a leftover from my mother when she moved into a retirement home. I actually put it on the curb a few weeks ago after moving it around my shop for 2 1/2 years and it was gone in about 10 minutes, so some old fart probably has it on their porch now. lol
Ta2ude
Fuck Carney
Thread Starter #103
The weather was nice yesterday so I put the collision insurance back on the car and took it for a test drive . It was the first time I had driven the car since the modifications and I have to admit I was a little nervous, but I wanted to see how it drove before it went in for an alignment. Thankfully everything seemed fine and it drove very well.
The only “issue” I found was the differential had a slight whine on de-acceleration. I did a google search and reports varied but apparently it wasn’t uncommon for people to notice this with the Detroit Truetrac. I will get the technician to look at it when he does the alignment and decide if it needs better adjustment/alignment of the gears.
Other than that it seems like everything is ok for now and I should be good for testing at the track May 9th.
Unfortunately Mother Nature is up to her old tricks and we got snow again last night !
Ta2ude
Fuck Carney
Thread Starter #104
If someone could provide a link or direct me to a post with alignment specs I would appreciate it.
Thanks
Factory specs in the front. Positive camber in the rear. I ended up with +2 degrees. Ran 1.25 sixty with that on a 315/60R15 Radial Pro. Key to straight line stability is zero toe in the rear. Make sure that if there's any error, it's to the inside.
Ta2ude
Fuck Carney
Thread Starter #106
It looks like the weather is finally on our side. Just figuring out where to install the etrack and the car goes in Wednesday for an alignment. Weather permitting I have been invited to a private track day May 9th !! IMG_7932.jpeg IMG_7928.jpeg
CPO Super stock
westminster
2021 Superstock
looking forward to some time slips. Have fun.
Ta2ude
Fuck Carney
Thread Starter #108
So I actually found specs that are supposed to be “optimal “ for my Gforce modified cradle set up and I had my car aligned today. Everything seemed to work out fine other than a possible u-joint that is failing and the likely suspect for the noise I was hearing. So for what they cost I am just going to replace the u-joints and hopefully that issue will be solved, but you never know. IMG_7940.jpeg IMG_7941.jpeg IMG_7936.jpeg IMG_7937.jpeg
