2016 Cat recall changes
A few people have asked for changes after the cat recall flash. The answer is really no change as far as the flash goes but the potential to maybe reduce even more torque. This explains why @moparjim still had so many issues after the update. Anyone curious around 0 DA I saw @vortecd 100% stock car hit 98% injector duty cycle on more than one pass. I can't remember off the top of my head but the car was going for .68 or .7x lambda something on full throttle and the fuel couldn't keep up. This was pre cat recall we won't be doing any testing before we tune post recall. No point @moparjim did that and there were no improvements.
@vortecd let me pull a stock file before and after the update.
After cat update
Before cat update
Comparison. The DTC show a difference but I didn't see anything
My car was maxing out the injectors from adding fuel and adding timing to burn it off apparently. My AFR was in the mid 10's before the recall was done. Basically why I had it done. Thinking something was off and this would cure it. Wrong!!
I will look and see if I can find a post recall, pre tune log to send you.
Right it will send extra fuel to cool the cats. Here is one of his pulls that day. factory is around .87 for normal power enrichment without the cats adding more fuel. Injectors just can't keep up.
This here was his first pass of the day
I keep getting letters about the recall for my 2015 and I keep throwing them away.
Did he log the fuel pump?
Mine was losing some pressure making the injector situation worse. Changed the fuel pump and the same results.
Yes. He did. That was struggling as well. I really wish the hellcat had dual pumps as well. I remember reading a lot of people running a 2.85 on hellcats without any fuel upgrades and that's just crazy.
I wanted the new parts, cats and 02's so I did it
I
I know a guy that ran the 2.85 on stock fuel system. He though I was nuts for suggesting he upgrade his injectors. As did his tuner.
He ended up having issues with the car and sold it.
This was a couple of years ago.
Since then I would have also suggested upgrading the fuel pumps.
I
Upgrading the injectors if only to Demon injectors would have gotten the job done.
I did the recall, then got a tune. I do have 2 pumps tho.
oilburner
coboconk
I`m getting my recall done soon going to walk into the dealer with my cats. the rest of the car will still be at home lol.
That’s funny. But they will most likely want to do the flash too
Let me know if that works for you, I'll do as well.
You got dimensions for that stand?
I'll like them if possible.
:whistle:
oilburner
coboconk
I know the service manager, he laughed an said ok . I`m only doing it to make dodge feel good an not send me any more mail.
oilburner
coboconk
:whistle:
I take no credit for the design @DemonSRT takes the credit but I did all the welding of it.
oilburner
coboconk
:whistle:
for sure!!
DemonSRT
Kawartha Lakes
I’ve raced a number Redeyes with my tuned 2015 Hellcat and we run door to door until we dropped at 145/155. I think most important I was with a 170 pax and they were alone so.. My tuned 2015 Hellcat has gapped a couple stock Hellcat every time so…
oilburner
coboconk
:whistle:
justed talked to @DemonSRT an as expected he has no problem.
tomorrow I will drop the car down attach cradle an take a bunch of pics an measurements for anyone who wants to copy.;)
it works fantastic.
there`s a separate support for rear of oil pan so you can remove trans as well.
