2020 NB Alignment??? Maybe not???
I’m scheduled to take the M6 into the dealer for its first wheel alignment this Friday. The only reason I am doing this is because textured roads (and most in northern Maine seem to be) will cause the car to pull in the direction of the texture. Here in NH it seems fine, and at Land Speed Trials it seemed fine (to 190).
1. Do you guys think I should just not do the algnment?
2. If I do do it, is it best to align to factory specs? I have 305’s on the rear.
My fear is that I don't want to fix something that's not broke. The car is fine on 99% of the roads I use. I just wonder if maybe the pulling on texture is a sign of poor alignment/worn parts. Cars has 18k.
I would appreciate your thoughts.
Thanks!
Thanks!
99%...I wouldn't fool with it...
thetalonguy
2017 Challenger HC M6
I can't speak much to what to shoot for end result specs on a diff tire setup, but can you have the shop print out the current specs results and compare that to how far out of whack it is compared to OEM specs? From there, you can decide if you want them making any adjustments.
If it tracks straight on a flat smooth surface and the tires are wearing evenly, I’d leave it alone. It’s normal to follow a road’s crown.
Not sure what tires are on my 06 Viper...(some sort of run flats)....but on anything less than a perfectly flat surface....the car is brutal,,,,:(
Thanks for telling what I was thinking, I cancelled the alignment. I have had good luck NOT messing with things that are ok so I'll continue that strategy here.
Back in the day, I had a 20' Hydrostream with a stock 200 Merc, it would do 79 on good water. In the 16 years I owned it I never let anyone touch the engine! I just changed plugs. When it was old, I needed to give it a bit more throttle when starting it, but it still did 79!
Hydro Streams were increaibly light...with that distintive nose..and crazy fast back in the day...my buddy had an 18ft,with a merc 225 black max...propped right 90+...all day long..
Mine was the Vegas which had a more conventional bow as opposed to the unique concave bow to which you are referring. But it had the XT hull, the "air entrapment" hull. And yes, the 18's were incredible, but could be dangerous. Lots of fun, as long as you are not a passenger!!! :ROFLMAO:
Nobody would ride with him...he was crazy...and the boat was flighty...(on lake Erie)...@ speed on a 1ft chop...he would air it out it would start to chine walk...and i'd swear he was goin over...it was"78"...we were in our mid 20's..half drunk...and no fear...:giggle::giggle::giggle::giggle:
thetalonguy
You must like to live dangerously…
Chine walking was typical, you just need to develop the skill of using the steering to counteract. Once you get it, you ride straight and level while constantly turning the wheel back and forth.
Back in 78 I had a flat bottom V drive...then in 85.. moved up to a 35' Fountain..with twin 500 mercrusers that stayed stock for two years...then the insanity started...TONS of money...think cars are expensive...try twin engine boats..everything is x2...stellings polished waterjacketed headers...tube within a tube...9 grand a set...x2...(and that was in "85" money)
