2020 Redeye hood intake bezels
Part numbers for left and right please.
Let everyone know how they work on your 19.
That might be what I need to keep the damm FROGS from living in my scoops.
COLUMBUS
KS
2020 HELLCAT HOOD Scoops are 05043113AB LEFT, 05043112AB RIGHT
COLUMBUS
KS
Here is a 19 hood scoop removed. It has the same 3 clips that clip into the 3 flat areas in the sheet metal at the bottom and the locating pin and corresponding hole in the sheet metal. All same as 2020 below it. If installing a 2020 scoop in a 19 all you have to do is make sure there is enough room for the nutsert to clear, otherwise remove it. This should also make it clear a 19 scoop should fit a 2020. If you look up the different scoop part numbers many sites show the scoops fitting both years. So I ASSUME they will interchange. I guess it’s possible the shape is different but it appears not. I went with a 2020 scoop because I want to use the nutsert provision and it is not much trouble to remove the grille.
Matt someone with an SRT
Newtown
Interesting.. my driver side one was loose the other day too.. front came up a bit.. I just pushed it back down into the clip and it’s been fine Since.. definitely like the look without the grille bit in the bezel.
VARedEye
Martinsburg
WV
Redeye
I was about to ask why anyone want these, but after the frog comment i see why.
Thread Starter #26
Left sides are available but right sides are not available.
Rochester
The '19 bezels come loose/pop up when you shut your hood if the double sided tape is no longer holding,
Living in the woods in South Ms, freaking frogs are everywhere. Frog shit all over car....
