Build progress
2ndgen
Orem
Any chance Kong will give you the part numbers on the bearings they use? Curious.
Thread Starter #22
They might have a part number on them, don’t know. For $650 they better be some good ones lol
Thread Starter #23
I’m still waiting to see what @16GoManGoHC2 has to say about taking apart the intercooler pump and slapping some rtv on there. I’m sure he’s had no less than 3 of them apart 😆
Jesse talked me out of upgraded bearings. Said he'd use them if I wanted to but that he'd never seen an actual bearing failure.
Thread Starter #25
Interesting, maybe they just get noisey then
2ndgen
Orem
It's not about outright bearing failures... it's about /heat/ (which can lead to failure--but "good enough" bearings will last "okayish").
Bearing friction causes heat--and it has to go somewhere... better/lower/non-friction seals, better grease (or an outright oil bath like Mike is experimenting with) can significantly reduce the heat produced (and thus also make it more responsive). Simply choosing the wrong grease can also result in early bearing failure--if the grease doesn't have a high enough speed factor rating, then at high enough RPM it can literally get wiped away and result in metal on metal contact--lots of heat and possibly also physically damage the race.
A full-contact seal accounts for as much as 60% of a bearing's friction--so you can imagine what going to a non-contact seal can do.
Thread Starter #27
So this is odd, this is the passenger side heater core pipe. Anyone have pictures of their front cover/valley where this goes in? Very strange, something’s missing
Thread Starter #28
I’ve had the supercharger off a million times and never noticed this. Why is my front cover missing the nub for it to bolt onto
2ndgen
Orem
Is it cracked off? Might need a new timing cover--or weld a piece on, machine/grind it flat to match, and tap it.
Thread Starter #30
No nothing was ever there
Thread Starter #31
This is an early 2015 m6. Anyone else have one and have pics of their valley? This is weird. No idea how I didn’t notice it when put the 2016 hard pipes in
Thread Starter #32
Thread Starter #33
I wonder if @fumanchu182 remembers if his didn’t have an extra nub on passenger side to bolt to
I have no god damn clue what you are talking about.
I think he's expecting a threaded boss to be where that bracket with the hole in it is to bolt the heater pipe to the block and or timing cover.
Thread Starter #37
Is that a factory hellcat timing cover? Every hellcat I've worked on has a 10 mm bolt to hold that on.
Yep, factory.
both tubes should have a mounting bolt to hold them in place on the timing cover.
as per mopar notice the passengers side doesnt have a tab, wonder what year this changed. Also the catalog has the wrong part identifier. Its all screwed up.
Thread Starter #40
Well, my car is an early 2015, and the hard lines are from a 2016
