Dead Jailbreak Charger
Blackjack77
Bethlehem
2023 Dodge Charger Hellcat Redeye Widebody Jailbrk
Problem #1: I was away on a business trip and couldn't start my 2023 Last Call Charger Jailbreak. When I tried - it was dead. I jumped it with the front posts since all electric was gone. After the jumper car idled for a few minutes, my Charger dashboard lights came on. I waited a couple of more minutes and tried to start it. The driver headlight flashed and the Charger died - now I have now power at all. The dealership said to tow it in. That stinks but okay. Problem#2: I had a steering wheel lock which goes on one of the spokes of my steering wheel. Since you have to turn it about a !/4 turn ti have it lock; my front wheel is slightly turned. I took off the steering wheel lock but ince the car will not turn on; I can't get the from wheels straight to roll it out for the flatbed tow truck. How can I unlock the steering wheel.
I think for you to get the steering wheel to turn, you will have to have electric.
I have a 2015 Charger Hellcat. I'm not sure about the Jailbreak, but my battery that I charge use is in the trunk. I know that's weird but that is the typical place the battery is for jumping and or charging.
Before I knew I had to use the trunk battery I also tried the front. And had that same experience of no charge.
This is not a Hellcat, but a Charger. I used a video like this.
Good Luck
~Linda
Blackjack77
Blackjack77
Bethlehem
Thank you, Linda. When you say that you you had the same experience - do you mean it didn't charge or that there was a flash and everything went black?
Welcome to the site and congrats on the car.
FYI:
Nothing to do with you, but you need to understand that people are leary about giving out info that may be useful to car thieves.
BTW:
Thank you for your service, and hope you stay around.
Post some pictures when you are able.
I had everything light up and then turn off because of no battery.
I needed a new battery which I also used YT for the How To too.
I would still try to charge the batter in the trunk first.
@Hunter is correct, Welcome to the forum!
I see you are not far from me. I am in Bucks County.
Once you get through all this and your JB is up and running you will have to post up in our New member section along with pictures.
~Linda
Put a battery charger on it until it is full. I've had the same problem with mine and I have to give it a full charge.
1.The battery is probably bad.
2. Put a battery tender on it.
HWDan
Home of the Hellcat
2017 Charger SRT 392
I could be wrong but I don't think these cars ever got a steering wheel lock. My 2017 with electric PS doesn't lock. You may just be fighting the wide body wheels to dry steer it.
Try lifting the front with jacks (one on each side) and try it that way without a load on the front wheels.
I agree that I don't think it's a steering wheel lock. But, things are just stuck because of no battery and you are probably correct about fighting the WB wheels.
I think he should try charging the Trunk battery, like @DavidKFla says charge until full.
If that doesn't work, I know I would be signing up for AAA and let them come out in a few days! ;)
This is a joke right?
MuscleCat
Doctor
DFW
2023 Challenger SRT Super Stock
I think OP made an intro thread last year... go back and see.
Hope you get it figured out @Blackjack77
U have jumper locations in ur engine bay bro if u need power to turn the wheel...... Just need a jumper box.
Blackjack77
Blackjack77
Bethlehem
Thanks for all your comments. Working the solution - getting a new battery - the old one was beyond repair.
Paladin 06 - why did you think it was a joke?
I think with a new battery your problem will be solved!
Post the update and Good Luck!
~Linda :)
I m curious if the battery itself was checked ?
Connections at the battery ?
Power at the jumper terminal ?
Make sure you also physically check all the grounds. Specifically the one that runs from the bell housing all the way up to the passenger side shock tower. it will attach on the back side of said shock tower and may be a bitch to get to.
That one stranded me in the car wash with a power but no crank condition.
