Dragrcr, thank you very much for the input.   So you're thinking the tires are breaking loose down the track?   It doesn't sound or feel like it but I'm open to it being possible.   Sure can tell when the stock tires break loose at 70mph on the freeway.    I was not aware you could run the tires as low as 14.   Wow.   I will run them a little lower then, probably 17 or so and see if that makes a difference.  Thanks again for the input.
Are you expecting the S/S to not have a hiccup even though it is essentially still a RE?    Would be a pisser if they fixed on the newer models and don't go back with a TSB on the earlier cars.   Keep us informed on the S/S.
 If you go back and look closely at that TECH Bulliten that I got that info out of you will see that smaller tires and heavy cars use higher pressures. Example big Top Fuel tires use 6 PSI. Tires are huge and cars weigh very little. They break the weight at 3000 pounds and the size at 30". So your car is 3000 plus pounds (needs more pressure) and tire is smaller than 30" (needs more pressure). These values are needed to support the weight of the vehicle and keep the tire from squashing when you nail the throttle and all the weight transfers to the back tires. With that being said, I have used 14 in a Hellcat before without issues but the Demon did not like it. The Demon had more power (distorts the tire more) and it transfers more weight (squashes the tire). With the 315/50R17's on the Demon I tried to use 17 and above.
With your car I would probably try to use 16 and above. But what if your gauge reads low? That is why I try things and I will go lower and try it. In NO CASE should the tire look flat. The tire should easily be supporting the weight of the Vehicle.
All cars lose traction down track, but most of the time it is very minimal so you are not aware. I was talking about the car losing traction on the shifts or at or near the gear shifts. I am not talking about a big spinning of the tires that will put the car sideways. This is why down track prep is so critical. It is hard to understand what is going wrong with the car and causing the Hiccup.
The S/S will have TCM programming similar to the Demon. I have experience with that car. Many times the car had a Hiccup and then I come back next week and it is fine. This tells me the track skimped on the prep on the bad week. Or it had rained and they did not compensate.
I have had times where the Demon hiccuped and then the next pass I saw them prepping right before I made that pass and it was fine. The prep really does have to be on point with these cars including down track. That's why I suggested you go to an event that ensures max prep like MSHS etc. Then you will know for sure.
If your car had a hiccup at the track I bet it was on the 2-3 shift. Data Logs show the 19's short shifting the 1-2 shift but the other shifts it is right below the rev limit.
YES, if you can run more pressure, by all means, DO IT. But don't be afraid to go down. I want to make good passes and I have learned to try things and adapt. EVERY time I make a hit I want to put up a good number. Every time.
Also lower pressures will make the tire spin on the rim more throwing off the balance. But I have a way of dealing with that at the track if necessary. So I do NOT let this affect what I am doing.
