Eternal 1.5 60’ club…
Thread Starter #21
LOL wut, you'd be dead ringer for the 10.0 class. Just take a degree or two of timing out.
I still have stock throttle body, stock unported supercharger, upper pulley only. Thinking may need the AAD arms as I was still spinning a bit
2021 Jeep GC 5.7 TrailHawk
What 3.70’s?
Thread Starter #23
Or just get the redeye zero camber rear knuckles but they come with new hubs and I just put new hubs on the car already. It’s the cheaper option,
Thread Starter #24
You changed the rear?
Thread Starter #26
I lose a few mph because of it and the transmission doesn’t really seem happy shifting because of how drastic of a change it is
Thread Starter #27
Stock rear is a 2.62
Moog offset bushings to fix the camber in the rear would be the cheapest.
I just ordered some myself. I have a wheel alignment sheet so I will know what to set them at to get it where I want it.
Thread Starter #30
I
haven’t heard of that! Do you have a part number/ any additional info on them?
I looked on Rockauto and they don't have it listed but they have the Mevotech equivalent. The pn for the Moog is K100173
This should give you an idea. Screenshot_20230326_123903.jpg Screenshot_20230326_123828_com.android.chrome_edit_2005878305938194.jpg Screenshot_20230326_123833_com.android.chrome_edit_2005907625878294.jpg
Thread Starter #32
So does this adjust camber or toe
Camber. It installs on the knuckle end of the rear upper arm. The Moog one has notches in it so you know what position you are installing it in.
I have seen those but guess you need a press to get the stock ones out and hopefully they are pressed back in where you need them
A press isn't hard to find if the trusted ball joint press doesn't cut it. As for where you need them they have a groove for different increments. I don't have the instructions yet but I'm sure you have to measure centerline from level or something. I will find out when I pick them up at work on Tuesday.
Thread Starter #37
I
watched a video for eibach ones for lowering springs and I thought you needed to press them in where you need them and then there’s no adjusting after that
Thread Starter #39
No, the 6 speed is a 3.70. Lol
You may want to go with a 3.09 or 2.62? You have way too much of a torque multiplier with the 3.70! It’s over a 40% higher torque multiplier than with a 2.62 in first gear! You need some monster slicks and wheelie bars!
