FI Supercharger spacer and blanket issue
Alain
Alain
Haskell
Thread Starter #41
To help you 100% grasp this There’s also a different nomenclature for the same bent using millimeters, 10PK1485 (1485mm long 10 ribs) is your 5100585 in inches :)
Glad we can help!!
yea, I stared at the part numbers for so long that I eventually figured out what that 10PK1485 meant hahaha.
thank you again man. This is why I love pur community and hobby ........people helping people !!!!
No kidding right . When I had my 15% underdrive pulley made I had to figure out belt lengths because I needed a shorter belt. I ended up finding the dayco app to find belt lengths and cross reference other manufacturers. It helped quite a bit . That's also how I found about effective length vs overall length . I'm glad some of my rambling helped lol .
Fwiw I have a ATI 10% O/D with 3 metco idlers and F.I spacers and I use a dayco 5100600 belt and it's right in the middle of the tensioner.
my tensioner should land right in the middle after the FI plate install and the new belt.
when and if I go to a smaller upper pulley the Gates, which is a bit smaller than the Dayco Im installing now, should work just fine.
im gonna go look for that Dayco app you mentioned.
thanks again !!!!
Look in our "For Sale" section.
Might find what you're looking for.
Alain
Alain
Haskell
Thread Starter #43
Thank you Hunter. I went with a new Dayco belt The belt on the for sale section was not going to be big enough.
Did the Dayco fit? I just installed new idler and tensioner pulley and my tensioner is to the left side like pic a few posts ago. Once I put the plates in there will be no way the belt will work. I was looking at the gates hd belt 100582 but I don't want the green belt 20200531_123046.jpg
I don't know how raising something up 1/2 inch in the same plane would cause any belt walk. It may draw attention to a preexisting problem, however, because it could be amplified.
The spacer is not 1/2 inch thick so......
I also haven't seen any stress on the belt either (belt shavings are a clear sign of either slippage or trying to walk off of a pulley).
@Paladin06
ZZZs???
Got 2 boxes of those blankets.
#48
Doesn't matter if it's 1/4" or 10'... if you're in the same plane, the belt won't pick a side if it's aligned properly. I was using 1/2" to make a point.
why Z's though?
So I did this exact mod and took her to MIR over the weekend. Good times had by all, not a single issue with the car. Boy am I glad I did the swap sooner rather than later. The gaskets where letting oil blow by, the crank case was definitely pressurized. Take a look at these POS gaskets.
#53
The ones from my Hellcat looked ok but the Redeye had some blow by for sure.
65222C81-64BE-41FD-9D2B-F3BA36D96019.jpeg 47F6B028-DC20-4D97-A282-A6DF2EBEBA56.jpeg 7A8ED401-0F2D-4578-925E-DD9DEBC26ADC.jpeg 7461457D-E8DD-46CD-8376-6A860AF62D1F.jpeg
My IC was pretty much oiled up... I'm glad I got rid of the bad gaskets when I did. I could only imagine how that engine was feeling after being driven.
Alain
Alain
Haskell
Thread Starter #55
Did the Dayco fit? I just installed new idler and tensioner pulley and my tensioner is to the left side like pic a few posts ago. Once I put the plates in there will be no way the belt will work. I was looking at the gates hd belt 100582 but I don't want the green belt View attachment 18034
Yep, Dayco worked like a charm. My tensioner is almost perfectly centered.
got the Dayco from amazon ! Easy peasy !!
on a side note, I strongly believe that whatever issues there may have been with the belt alignment after the spacer install must be due to people not replacing the dowels on the bottom of the supercharger with longer ones.
they locate the supercharger precisely where it needs to be. Without those, you are relying on eyeballing plus the bolts lining it up for you.
Remember that openings for the bolts on the supercharger and on the motor are slightly bigger than the Bolts themselves (to allow the bolts to go through). This will cause you to be off alignment ever so slightly, which may be enough to cause issues withe the belt when it is under load.
the dowels On the supercharger and the holes for the dowels located on the motor are a super tight fit, ensuring there is no room for play.
take the extra steps and replace the dowels. They are super cheap and you don’t need any special tools to take the OEM ones out, just patience. Worth the peace of mind, in my opinion.
Friend of mine couldn’t get the old ones out. Trusted the bolts, and it’s working well for him. I’d recommend getting them out at all cost.
I bought the kit from one of the members in the old site about a year ago or so. i am finally getting around to installing the kit now.
As I get ready to do so I am learning that there have been instances where after install, the belt will “walk” itself onto the pulley snout.
supposedly this is due to the change in geometry caused by the added 10mm of height from the spacers.
I plan on reusing the stock belt since I won’t be changing my pulley.
have any of you head of this or experienced it?
I have the spacers & TBA 2.85 pulley & have not had any issue with my belt or pulley.
There has been some issues with the Listens pullies walking back into the snout when a clip has broken enterally.
Alain
Alain
Haskell
Thread Starter #58
That’s news to me. I hadn‘t heard this before. I thought Litens was a good product
They are good but there was a bad batch with issues a while back. I know there is threads on it & a buddy works at Peitz Performance & he showed me one first hand on a Track Hawk , pulley broke & went back into the snout.
That is good to know since I already ordered the belt. Haven't read anything about the dowels. You wouldn't know the size and length needed? I think Ace Hardware would have them.
