Found while detailing trunk.
So, I am detailing trunk area (as we all know how waterproof they are), when I noticed that the plastic was not centered.
Anyone seen this before, know what it's for, or how to get it out?
AeroF16
It's a screw, seen a bunch of them before. Typically used for holding things together.
You can tell it's a screw by the way it is...
@Hunter we never said you had screw loose, but, just sayin’....
Can't you just grab it with a needle nose plyers & wiggle it out by pushing on that plastic bit thata butts to the metal ?
Big question is, was it an 'extra' dropped during assembly or has it worked loose from something ?
Tried.
Plastic wouldn't budge.
That was my thought.
Was it an "extra" dropped in, or a screw that has come loose (from somewhere).
If a magnet will grab it, you could pry off that plastic drain cover, drag it over to the hole & grab it there ? Assuming there is nothing on the underside of that metal lip to stop it.
OR - pop off that decklid cover & just grab it. Then you could look around with a flashlight & inspection mirror to see if there is an empty hole where it should have been !
It's a gov't tracking device. You're being watched.
Gently flex that vertical wall out of plastic and grab it with some small thin needle nose pliers?
Burnsville
Should I have that?? Mine doesn't have that!
Class action lawsuit coming because I'm missing a screw!
Want to see screws everywhere...look inside the walls of a THOR Motorcoach.
Not all Challengers get that special alligator deterrent screw.
Like a Hot Wheel with a defect I guess your's is worth more:) Or maybe your spoiler is going to fly off:unsure:
Put a drop of superglue on it so it doesn’t rattle or travel?
why2kmax
12 Second Best E/T
Shrewsbury
The screw isnt rusty therefore no class action suit
Buy some insulation spray foam:whistle::whistle::whistle:
AeroF16
I'd sell the car before this goes South...
I’m try be in Gautier 4-6 tomorrow for cruzin
