Occasionally under medium to heavy breaking, when I come to a stop I hear a noise from the front left that sounds like a mechanical component of some kind resetting or cycling, not a whine or a buzz but a clear two stage knock.  As soon as the car settles is when it happens. If I brake nice and easy, nothing. I'm going to check the rotor ring nuts this weekend. The lugs and mounting surface are clean and tight, torqued correctly etc.
Has anyone else experienced this?
 Ok here is the video. Right about the 00:00:14 mark you’ll hear it (may need headphones).
https://youtube.com/shorts/QVuRPgbQCCY?feature=share
-It appears to be coming from the engine bay, specifically front left
-Happens every drive when starting cold
-Usually around 5-7 minutes into the drive
-Occurs after completely stopped and the vehicle is still for about 12-15 seconds, give or take
-I never hear it after the vehicle is warmed up, nor does anything replicate when the suspension is in motion (speed bumps, pot holes, extension, compression, etc.)
-Visual inspection on a four post lift doesn’t reveal anything loose/broken/out of place
-For what it’s worth, I don’t “feel” it at the pedals or the steering wheel
-I agree that it is a double “clunk”, and seems to be something mechanically actuating/cycling
@SDREDEYE , is this similar to your issue?
Thanks all for the video posting help.
