Front sway bar removal
The Englishman
Newbury
United Kingdom
2018 Demon
Anyone give any insight into how a challenger behaves on the street with the sway bar removed please?
I've driven my RE a bit with the sway bar removed and it hardly notices it's not there. I typically take it off before going to the races and put it back on shortly thereafter. In my mind it works the shocks harder to keep the car flat around corners and the last thing I want to do is wear out those high $ shocks.
The Englishman
The Englishman
Newbury
United Kingdom
2018 Demon
Thanks Bo,does it take long to take out,do you do it on a lift?
It's easy and quick. I use my race ramps, they get it high enough but just barely.
Once I learned the 3 or 4 sockets/wrenches I need to do it I just keep them together in a box so I don't have to go through that every time. Once you've done it once it's probably a 15 min job. The first time will take you a bit longer.
The Englishman
The Englishman
Newbury
United Kingdom
2018 Demon
Thanks For the info,I’m going to the track this Friday so may take it off👍
oilburner
coboconk
mines been off over a year an notice no difference. I`m sure I would notice on a circuit track but that`s not going to happen. straight line for me.
Post the part number and weigh it
oilburner
coboconk
I`ve been told 24 lbs. with links.
I took mine off a couple weeks ago & went to the track once so far & didn't notice much difference at the track, the weight savings is nice. On the street it's not bad either as long as you don't go in to corners very fast. Normal driving you will forget it's not on the car.
Maxboost
Fuquay varina
NC
Definitely different driving manners but only when the car is pushed. Mine has been off for a while with a lot of daily and track runs. I don’t feel the need to put it back on. Obviously strut tuning will make it ride different but I’m running the demon drag mode like you.
The Englishman
The Englishman
Newbury
United Kingdom
2018 Demon
Thanks for the replies I’m taking mine off tomorrow for a ninety mile drive to the track so if I don’t post after Friday you’ll it didn’t work for me .😬
I drive 60 miles (1 hour) each way to my track, you should be fine, just don't take sharp turns or corners real fast.
The Englishman
The Englishman
Newbury
United Kingdom
2018 Demon
Mine weighed 11lb 6oz
And it drives fine, thanks to all for the input 😁
Maxboost
Fuquay varina
NC
Was that with all the hardware included?
The Englishman
The Englishman
Newbury
United Kingdom
2018 Demon
Yes, that was everything , I thought it would be more than that, easier than dieting tho🤔
The Englishman
The Englishman
Newbury
United Kingdom
2018 Demon
Here’s the part number
I didn't realize it was a Demon. That is the 221 Demon, 1320 sway bar
My sway bar assy weighs around 25 lb complete. I knew the Demon bar was a good bit lighter, it's nice to know the exact weight.
Hope you had fun at the track.
The Englishman
The Englishman
Newbury
United Kingdom
2018 Demon
Great fun, it was a mustang meet with a few challengers throw in to make the numbers up .
I'm happy that you got to go to the track. Sorry to hear that you had to hang out w a bunch of Mustang guys though. lol :p
