Hellcat SRT button Sticking in.
Matt someone with an SRT
Newtown
As the title states for some reason now my SRT button on the center dash is sticking in. I can pull the tab underneath to get it back out but it won’t come out on its own after being pressed in. I tried pressing it in and pulling it back a bunch of times still sticks. Any suggestions? Should I spray some contact cleaner in there? Has anyone heard this happening before I didn’t ever have this occur in the other 3 mopars I’ve owned.
Well that sucks Matt. Obviously at a minimum that part of the “stack” may need replaced. Someone will chime in to recommend an electronic tolerant spray. You may also try one of those air keyboard blowers or simply take a high pressure air blower off a air compressor if you have one, some little POS may have got unexpectedly lodged in there?
CRC makes a lectra motive spray that I use on electrical contacts. Not sure if it's right for your situation.
45-70govt
Ghetto
Maybe try some compressed air to blow out something that may have gotten in there?
Can you say if the issue is internal mechanical binding or due to a piece of debris (food?) that got in the edge gap somehow?
If you think it's something that got in there and hitting it with compressed air doesn't work, I would remove it, and try something like either the contact cleaner above or maybe even just IPA.
Let it dry thoroughly prior to reinstall.
Newtown
I doubt it’s food or debris it’s the new jailbreak I don’t even have 500 miles on it and I haven’t eaten in the car hah. I’m wondering how I would remove the button?
Oh take it in to the dealer! Easy one then.
The start button?
It only took 7 posts to get here! ;)
He didn't say that it was a new car.
Either a 2023 or a 2019, so 50% chance.
I'd see if the dealer might fix it free regardless.
I try to stay away from the dealer.
Agree, if I can fix it myself easy and cheap, I'd do it, if not, let the dealer do it.
Diboblo
Riverside
2015 Dodge Charger Hellcat!
DON'T SPRAY ANYTHING IN ANY BUTTON!!!
The return on these buttons is a rubber membrane. They are not old school mechanical buttons.
If you're talking about the START button, it easily comes apart, for cleaning.
If you are referring to the SRT button, on the climate control, that also comes apart pretty easy. If it is sticking, the rubber membrane may have cracked and won't allow the button to return. Can't tell, without opening it up.
Hope this helps.
Diboblo
Riverside
The dealer will not fix it. They do not do component level repairs. They will just replace the module.
So...let em replace it...why fuck with it...
recurveman
Smithton
2021 Challenger Hellcat WB
It’s under warranty. If you try to fix it and screw something up then take it to the dealer they just might not deal with it. Why do it yourself?
Diboblo
Riverside
Sorry. Missed the warranty part.
Yeah. Swap it out.
Probably just needs to be cleaned but take it to the dealer let them figure ut out
