Hemituner Forged Engine Assemblies
Trader history for Hemituner (0)
Hemituner
Bayshore
2018 Demon
Introducing Hemituner Perfomance race engines. These Demon/Redeye based longblocks feature 9.5:1 compression with a Custom CP, or Diamond Piston has you covered through the 1000 WHP range. Molnar or Callies ultra rods, Ported heads, PSI valve springs,ARP Head studs, ARP main Studs,Demon cam,upgraded Pushrods, and a Pinned ATI damper are all standard. Stock Cranks and Blocks are Stress relieved and cylinders Torque plate honed. Engines ship full of oil and primed. Brand new Genuine OEM lifters, new timing Chain, guides, covers, oil pump , cam-phaser vvt solenoid, water pump , and hardware. Black Valvecovers are standard Red is available as an upgrade. Track Tested and proven Tim Barth and myself have done the work putting these through their paces all summer in our campaigned cars. Run 8's and 9's with confidence. $15,000 Plus Core
Taxinator
SANTA CLARITA
2017 Charger SRT
🤤 someday...some...day!
Sounds like a nasty motor. What are the benefits of starting with the Demon/RE block?
Very nice!
45-70govt
Ghetto
Dear Santa…...
I’ve been a good boy......
H
Hemituner
Bayshore
2018 Demon
The block itself nothing. I start with them as cores because I like the tool-steel cam.
Thanks
AJ
Hellcat wiring harness and computer still a plug and play set up with that? (with a custom tune, obviously)
H
Hemituner
Bayshore
2018 Demon
100% plug and play.
Thanks
AJ
Now that is remarkable and the price is nice. Sell Cole a couple more gallons of shine,,, and one could be mine. Wake up Cole or are you still in a coma??
