Lightest front runner?
For 18 inch wheel what's the lightest? Race classes seem to be changing to allow non dot fronts and my m&h fronts are heavy.
@Hatermkr knows these kinds of answers.
Lightest tire or wheel?
Tire, I already have 18" Dark Star wheels that are pretty light.
Your m&h bias ply tires are heavy? These are 16 lbs each.
M&H Racemaster Bias Ply DOT 28/4.5R18 Front Runner Drag Tire.
My ET street fronts are light, but over loaded
I'm curious about mixing bias ply and radial tires? That used to be a no go?
oilburner
coboconk
I didn’t like the M&H for stopping or turning. Flimsy feeling sidewall and the wheel is exposed to impact on the rim with the way the bead/sidewall is with those. I like the Hoosiers for 18” wheels but I’m running the M/T Fronts on a 17” wheel now (lighter). The Hoosiers are commonly used on fast Hellcats with a 18” wheel. Jegs says 12 lbs. We use them on the blue car and it’s 175mph in the 1/4.
My car seems fine with the mix
my wheels were mixed biased on the front for my pass last week. It was pretty smooth. Really the lightest front is the Hoosier on a 17. The new Mickey Thompson front radials are pretty nice. I had two sets of m&h tires split on me and I won’t run them anymore.
Thread Starter #13
From memory bias front radial rear is OK, vice versa can get a little wierd at speed for sure.
Trackhawk, RS3, Golf R
Hoosier is the lightest I know of.
What tire you running in the back?
I use that tire an I like them. on18 inch forgestar wheels.
I just checked. My M/T Fronts (27.5” tall) are 12 lbs. Billet Specialties wheels are 10 lbs. So… 22 lbs each side for the wheel/tire combo. IMG_2996.jpeg IMG_2859.jpeg
oilburner
coboconk
With your brakes would 15's be lighter?
In this case the tire is heavier than the wheel so more tire and less wheel probably wouldn’t be lighter. I do not like the larger sidewall on frontrunners.
