Wait a couple of weeks so 1) I verify it can be done successfully and 2) see if the V-clamps make it as easy as it looks to connect/disconnect the bypass pipes and the stockers.  One thing I know already because it cost me $130 is be careful removing and screwing the damn sensors in and out.  OR just get a couple of blanks to screw into the by-pass pipes and then just suck it up and connect/disconnect the sensors’ electric connectors.  The week after RA I am having the boys weld the connectors up to the system and the two sets of pipes to return mine to stock for the streets again.  If it all works well, I bet it can be changed out in less than 30 minutes easy.
Because I don’t know what you used for an adaptor on your by-passes, but the set I have has a skip-in one and that bastard won’t come out unless I destroy shit damn it!
