"Project Demons Breath"
Thread Starter #1,181
Is the RE & Demon the same or do they differ?
Same . The factory demon driveshaft ends on AA . The redeye has the same numbers but ends in AB .
Curious how much it weighs.
So before you install it you need to weigh it for me.
Please.
Thread Starter #1,183
Please.
No problem
No problem
Actually you need to have Jim try it first to find out if it’s breakable.
Thread Starter #1,185
I'm not letting him anywhere near it !
Thread Starter #1,186
Please.
33 lbs 12oz with all the bolts
Wow. Pretty heavy.
Thread Starter #1,188
Wow. Pretty heavy.
Demon driveshaft = 33 lbs 12oz
CCI Driveshaft = 21 lbs 12 oz.
But to me worth the extra weight . My vibration is finally GONE and the car is smooth as glass up to 225 KPH(139 MPH ). I am really happy with the outcome.
Thread Starter #1,189
A big shout out to @oilburner for letting me use his hoist to install my new driveshaft today. It made it definitely easier to do. I`m not going to bore you with pictures as it has been done many times. I was a smooth install and I got to fix an exhaust leak and a missing nut on the starter heat shield. .
Also a big shout out to @motorheadmike for talking some sense in to me about the while driveshaft debacle . When installing the demon/redeye 2 piece driveshaft i noticed the the front section from the transmission to the hanger bearing it has 1 angle and the rear section from the hanger bearing to the differential has a different angle. Add that to the length of the 1 piece no wonder it vibrates . I personally have nothing but bad luck with 1 piece driveshafts on the late model challengers. I have tried multiple manufactures and multiple materials. There may be a weight penalty but worth it for me.
FFBOS
Mount Prospect
2016 Hellcat Charger
What kind of vibration were you having with your CCI?
Thread Starter #1,191
It would start vibrating at around 120 mph and progressively get worse with speed .
I did a test yesterday. I brought up the rpms a little higher than normal. Ok more than a little. LOL
Guess what...I felt the vibration I was having at the top end at times. Poop
oilburner
coboconk
its a much higher frequency vibration than lets say a tire out of balance. almost a buzz like vibration.
the faster you go the worst it gets like Hpindy said.
FFBOS
Mount Prospect
Mine was never that bad, but started having other issues after 12 launches or so.
Thread Starter #1,195
Not everyone has issues with their driveshaft. Unfortunately I did . Like I said between 2 cars I tried 5 different driveshafts from 3 different companies and had bad luck with every ones of them .
Maybe my cars are junk
Grape Ape
Braselton
No only cartoon colors at the moment.
A large number of cartoons are about super heroes. I think purple is a good super hero color. :p
Beast707
Carol Stream
2018 Challenger WB M6 Hellcat
Incredible Hulk originally had Purple Pants!
Grape Ape
Braselton
Thread Starter #1,199
I like the way you guys think
FFBOS
Mount Prospect
Hopeful the charger redeye has this beef shaft. Looks like it’s listed in parts, but I’ll wait for some results on a tire and 900+ wheel before I look at it.
