Running 9's in Florida HEAT
ellenton
2016 mango hellcat challenger
NEW MEMBER - I've had Hellcats since 2015 - my current car has a Barth 900 kit, 916 at the wheels - I have Demon springs - 15" conversion front and rear - Sphon rear arms and my own custom toe links I sell for $325 shipped to lower 48. The car is full interior and full exhaust - For these runs I’m running a soft Barth tune just for test’n tune - car runs very consistent - leaving off idle with 315/60 street Rs
I also have an Active Interchiller to keep temps down - The kit I used is true bolt in kit and my car is the car they used to perfect the kit - so if you are looking for help figuring a kit out let me know - I also do installs if you are in SW Florida at my personal shop - filled with factory refrigerant and there are no headaches - make sure you get in touch with Dave at Active Interchiller https://www.facebook.com/Interchiller/ if you want to order a kit!
Temps after last run on return road - IATs never went above 110
My 100% Chromoly Toe Links - no grinding - fully adjustable - tested to 1.33 60' (and will go faster)
not bad for a full weight car that drove to and from the track
RedEye19FL
Bradenton
2019 TorRed Challenger RedEye
Welcome aboard neighbor. I'll have to come see you run at Bradenton Motor Sports sometime.
Very impressive 60’s! Good job
Congrats , nice passes !
ST PETERSBURG
05 Maggie GTO
Congrats, did you make it to Fl 2k?
