RWHP with this set up - prognosticate / hold forth
1. 2.85 pulley
2. tune / new PCM
3. injectors
What is your say on RWHP? What would you add or take away?
YMMV
Morris Co
18 Charger HC
Around 750rwhp give or take (depending on dynojet/mustang, weather, da, tuner, etc) on 93 pump.
Are you doing the 180 t-stat, new plugs, & pinning the crank?
Hemiride
Farwell
I would definitely go with a litens decoupling pulley.
I am thinking of exactly the same setup for mine.
I plan on using demon injectors. I won't be pushing it any farther than that.
Drive shaft?
rdlsrt
Pearland
If not planning on taking to track, do you really need a drive shaft or pinning the crank?
Hemiride
Farwell
Not going to track my car. The 16s are supposed to have a better drive shaft than the 15s.
My son just talked to the president of Litens. He told him that the DS are too long to be one piece. There are 2 places that make a 2 piece shaft but they cost $3200. I'm not dropping that much coin.
I wonder if a redeye shaft would work?
Hemiride
Farwell
Some say u must pin the crank. Others say not necessary.
My feeling is that most of the crank spinning issues were back when the metco pulley was being used. Now that litens has come out with smaller sized decoupling pulleys I don't feel it's imperative to pin your crank. I'm not going to pin mine.
Hemiride
Farwell
I should mention that my son talked the president of Litens today and was told that litens is or has come out with a 3.17 pulley that was tested on a stock hellcat. It made 50 more hp and didn't require any other modifications. That's right no tune no injectors just pulley. According to litens pres. The factory pc/tune compensates enough to be safe.
So if your not into doing all the other stuff like tuning data logging this might be the route to take
Hemiride
Farwell
Is that crank or at the wheel?
Hemiride
Farwell
I wondered that myself
If you're not gonna track the car, why add more power?
@Speedy! - More power on the street is just as much if not more fun. If power on the street wasn't fun, we would all have dedicated - unregistered - race cars. We wouldn't care about factory performance. That's a weird question... lol
My concern about Liten's claims is that if you're in -DA, you may run short on fuel running that pulley without a tune. I don't know, which is why I said "may" ... If people are seeing STK with stock boost stock tune, they'll see it on more boost stock tune - but the stock tune may not be able to compensate quickly enough to save you from trouble.
Also, going through the hassle of putting a pulley on - just do the tune, make more power, be happier :cool:
JRabq
I have that slow M6 with only 707...lol. What's better than too much...well, more sounds better!
I'm gonna have to disagree. 700 hp is plenty on the street. I don't know where you guys live, but I couldn't use all of the power my Hellcat had stock on the street. At the track I want all I can have. I came from a different time though when the best you could get was 425HP stock and we had to build motors, supercharge, etc just to get to 650 so my perspective might be different.
JRabq
Your perspective totally rational...just yankin ur chain a bit.
True, I don't particularly plan to track the car (no tracks here makes that a problem) but I still find use for additional power, even on the street. Out here in the big empty there are places you can make your own psuedo-track (not as good as the real thing, but still allows some semi-quick competition in a safer venue than street racing). And as the kids get older and more time becomes available I would likely be more able to make the run to the nearest track.
Built up turbo set ups (I much prefer the factory set up if you go turbo, but that's me) and super charged engines (my personal preference from reliablity and less hassle perspectives) in the past, and of course, NA too, and I still prefer more power. lol, just my personal failing. Can I live with the car stock? Obviously. But if I decide to keep it, mods will be on the way. And even with no track, straight aways and on ramps will be just a tiny bit more fun, at least to me.
To Jack's point, I've been wondering myself about how well that new pulley offering will truely integrate without a tune. An interesting engineering problem. Especially if you have to operate in a comparatively high temp environment.
Out in TX the land of the flat I bet you can find some places to stretch her legs.
I'd have to run some calcs to see what's what on the pulley and no tune. The wide bands are designed to adjust fueling to maintain a certain lambda value, and this may be just under their limit. I'd get with some tuners who've tested it to find out for sure.
Unless you're lined up with a lighter, more powerful, car - on the street. We aren't pretending that street racing doesn't exist on this forum are we?
I could have used another 200hp in my last race...
Granted, after that run he left the bottom half of his motor on the road and it cost him $10k to prove that a turbo Camaro could make some power... but he proved it on the street, and I proved that 700hp wasn't near enough.
All good, some people keep it on the track for 10-11 seconds at a time, and I like that too.
