Saved a few bucks
Turned out to be a cheap fix for a nagging problem. Why this worked I have no idea, but is what it is.
How many more miles or time since then?
Months and probably 1500 or so.
Slows2k
2018 Challenger
Did you clean either of the rear 02 sensors? Leaded fuel even in small quantities doesn’t always agree with the sensing element. From your last track video, a little leaded fuel has passed by those sensors.
A small exhaust leak at the sensor can also cause the P219A/B codes, and reinstalling the sensors and compressing the sealing washers can fix.
Blkout
Warner Robins
From a logic standpoint though, this makes no sense and the problem should return. If the original passenger front O2 was the culprit, as Speedy stated, the problem should have followed the sensor to the drivers side and it didnt which says that the sensor wasn't completely bad. Swapping the front passenger side sensor with the rear passenger side sensor should in theory have done nothing. The fact that the problem hasn't returned yet tells me that it will happen eventually.
The only way this could have worked without the code coming back is if the front O2 sensors on both sides are slightly damaged or out of tolerance enough that they aren't providing accurate readings but the rear sensors are still good enough not to throw a code.
Blkout
Warner Robins
This is my thought, the front O2 sensors are slightly damaged and not providing accurate readings, the rears are still good enough to pass, for now.
Nope didn't clean them. Crushing the washer is a possibility but they were all tight.
Just for terminology clarification they are called upstream before the cat and downstream in or after the cat.
@Speedy did you scope the sensors to see if the upstream or down stream sensor was reading slow ?
great video
I’d take the hp tuner and have the car idling and watch the af sensor on bank 2 while spraying a little starter fluid around the intake manifold and see if it goes rich if all is well you may have an injector or ignition coil issue at one of the cylinders, also long term fuel trims readings may help determine if it’s adding fuel for a lean condition , could possibly be one if the fuel injectors orings not sealing
When my poor critter ingested leaded fuel, it got sick,, real sick All sensors had to be replaced, exhaust gasket, fuel rails, and the converter. A couple of times. 4 tanks of 93 and she feels much better,
Slows2k
2018 Challenger
Lead doesn’t come off the catalyst substrate or sensing elements easily. In my experience both the upstream and downstream sensors are used in any AF/02 sensor DTC logic.
Speaking of Tenn. Me and the cat maybe making a trip to Chattanooga for a 4 month contract job. Cold. But kills the fleas.
I didn't scope them, check with with a multi-meter, or anything like that. Never had to go that far. Weird that swapping sides fixed it though. I've run my leaded gas mix through it 3 times now since that video was filmed as well and so far so good. Mike said he'd seen this pop up on modified cars from time to time and it's random.
Maybe it's a case of values being just on the edge of thresholds, by moving them, you moved one sensors variability to the other side, and to a slightly different environment.
