Tire wear
Thread Starter #2
Do I need to adjust anything in the rear suspension? Car seems to pull straight.
Seems like passenger side is off compared to the drivers side
cars pullin straight????....cant be that bad...start adjusting things it may get worse...
Yeah, if it ain't broke don't fix it. Just seemed like I could make a little adjustment and move the wear line more towards the center.
Have the aad arms...
I wouldn't use those in snow.
Only way to adjust rear alignment is with aftermarket arms
Yeah just not sure what I'd need to do. If I do anything. It goes straight so hate messing with something and have that change
So, if I understand correctly, both tires are more worn on the left than right.
How much do you weigh? ;)
HWDan
Home of the Hellcat
2017 Charger SRT 392
Congratulations!
This is the kind of tire wear that puts the smile on our faces.
Decay
Astoria
OR
2019 widebody Redeye
Mine normally wear out the insides first like the car is squatting down on acceleration.
NTO's
You can make them wear evenly by going faster through the curves.
NTO's
for as often as I drive...mine still have nubbs on em...
Nah both back tires one drivers side and one passenger side
Sounds like you just need new tires...:unsure:
Got new mickey thompson street radials for it. Previos tires were the nittos. Great on the street.
Just wondering if I should adjust the suspension so the wear line moves over and more matches the drivers side wear.
Thinking negative camber would be the adjustment id need
If I could get a pic of the tires on the car, I could make a better determination of what is needed
Just realized my mickey thompson 325 35 radials are going to be shorter than the nitto 315 40 radials. Hope they hook good or better than the nittos
