Water to air chiller missing
Sheboygan
2016 Hellcat
My Redeye don't have the small driver side lower grill chiller like my hellcat did?
And there is a rag/cloth laying in the bottom of the area where it's supposed to go viewed from the tire side screen.
Bixby
OK
2019 Dodge Challenger Hellcat Redeye Widebody
Had the same concern when I got my Redeye. From what I’ve been told. It’s lacking the additional heat exchanger/cooler because it has the A/C Freon cooling, or factory Killer Chiller arrangement. So, it doesn’t need that extra heat exchanger. Mine also has that cloth at the bottom as well.
zhc
7 Second Best E/T
2016 Dodge Charger Hellcat
The cloth is to catch any condensation that drips from the factory chiller setup when it gets cold.
45-70govt
Ghetto
Constantly damp cloth----sounds like corrosion city in a few years.
Saint Paul
Dodge SRT Demon
The sanitary napkin.
Will dry on the next pass at the dragstrip.
Confuzed1
Go Pack Go
I never knew the RE's didn't have that heat exchanger!! I've learned something new today! I wonder why they didn't have one that helps during normal non-track mode driving, and just bypasses it in chiller (track) mode?
zhc
7 Second Best E/T
I imagine the number one reason is that it minimizes the number changes needed for fitment if they put the factory chiller in place of where the aux heat exchanger would have been. In fact, that’s pretty what they did.
Bixby
OK
Wait. Let’s be clear about this. All Hellcats and Redeyes have one larger heat exchanger, in front of the radiator. However hellcats have an additional/extra smaller heat exchanger as well. That smaller exchanger is what’s removed from Redeyes. Not the larger main unit. So, yes. We all have a heat exchanger for everyday, day-to-day use.
If you didn't you would know it Just hope you don't start seeing green/// Two different metals with out a dielectric union means trouble//
