Why store with a full tank of fuel?
I've seen several of you post that when you store your car, you top off the tank with fuel. The fuel tank is plastic, so I wouldn't think topping it up is needed unless you guys worry about condensation some how? I'd wonder if the fuel is still any good after storage for 5 or 6 months?
I normally drive mine at least once a month, but we've had terrible weather lately and I'm wondering how long I can wait before getting it out for a drive.
I’ve always topped it off because of condensation, but that might not even be a concern these days with ethanol in the gas. I also add Stabil to the last fill up and the gas seems just fine in the spring. BTW and FWIW, Project Farm did a seemingly valid test of fuel stabilizers and Stabil was a clear winner.
I did put some Stabil in the tank last 93 fill up - but I typically only keep 1/2 tank in the car as I never know when I'll wanna go from 93 to E85 or back again.
personally, 6 month old modern gas causes me zero concerns, and is actually quite "new" in my world :)
I went for a little ride today 37 but beautiful blue skies.
I have been messing with engines since the mid 60's, never had a problem, even here up north. I mostly don't worry about it. I do drain the carbs in my lawn mower and wood splitter. And I don't race the cars until the old fuel is burned up. Hope everything will start next spring! :)
But if I had to think about it, I would leave the tank near empty and let the ethanol soak up the condensation, then run the tank empty in the spring, then start fresh.
Since switching to E0 and Stabil, I don’t even bother draining float bowls in my outdoor power equipment anymore. Everything starts right up in the spring.
I've always heard that it's about air volume which in turn equals amount of condensation.
If the available volume of air is minimized, so is the condensation.
Reality? Who knows...
and the parts most impacted by condensation in your tank are at the top, most exposed to it.
5/6 months...it will run I wouldn't beat on it.
