Z’s Charger vs 8 Second Foxbody
I had a thread on the other forum but I stopped maintaining it after I started coming here. It doesn't have any of my recent endeavors or anything about my current setup with the 428 stroker and 4.5L Whipple. Maybe when I get some time to myself, I can put together something here.
For now, I guess I can list out my mods.
Basic setup
225 shot of Nitrous on a built stroker motor with a 4.5L Whipple on top pushing power through a factory upgraded HP90 8 speed transmission.
Weight is a touch over 4300lbs with driver
Build Details:
- Demon Performance/TKM Built 428 Stroker Motor
- Thitek Custom Heads
- Demon Performance Blower Cam
- Paramount Performance Built HP90 A8
- Whipple 4.5L Supercharger
- Nitrous Outlet system with custom nitrous spray bars
- Killer Chiller with extra 1.25 Gallon Intercooler Reservoir Tank
- Genuine Lower Rate Dodge Demon Front Springs
- Menscer / Reed Performance Rear Double Adjustable Racing Shock and Spring
- Injector Dynamics ID1700
- Fore Triple Pump Return Style Fuel System
- JMS FuelMAX Dual Output P2020 Boost a Pump
- Stainless Works Long Tube Headers
- Mopar 3.09 Factory Rear Differential
- BMR Upper Control Arm, Upper Trailing Arm, and Lower Trailing Arm, all with upgraded Delrin bushings
- BMR Solid Cradle Bushings
- Per4mance Development DIRS Diff Brace
- Per4mance Development Billet Front Diff Race Brace
- TCE 15" Rear Brake Conversion
- High Horse Performance / Bogart 15" Rear Beadlock Wheels
- Mickey Thompson 315 ET Street Pro Radials
- TCE 15" Front Brake Conversion
- RC Comp Hammers 15" Wheels
- M&H Front Skinnies
- Driveshaft Shop Aluminum Driveshaft
- Driveshaft Shop 1,400 Half-Shafts
- Anti Gravity Lithium Ion Battery
- 180 Degree Thermostat
- ZAutomotive Tazer
- ZAutomotive Double Bypass Cable - allows use of Tazer + Datalogger simultaneously
- Custom Modified RPM Roll Cage
- Stroud Parachute on custom mounts and hardware
- ATI lower with Hpindy's underdrive accessory pulley ring
You are shockingly fast for the parts list you have posted.
I tip my hat top you . Well done !
Octanewide
House of power
That's getting it done especially for a big gurl..Congrats
Basic setup
Build Details:
- ZAutomotive Tazer
Impressive! Amazing the stock diffs are holding up.
Z... question regarding your front brakes. How is the stopping power on those? I am going to be looking to reduce weight where practical and there’s a lot of weight to be saved by ditching the stock Hellcat boat anchors. Can you rely on getting stopped without the chute. I don’t like the idea of actually need it to get stopped.
Z
zhc
7 Second Best E/T
2016 Dodge Charger Hellcat
Thread Starter #25
My car has no problem slowing down without the chute. I generally ease into it but you have to be careful on tracks with shorter shut downs. You can run out of real estate pretty quick at 160+. I generally don't pull my chute unless I'm over 156-158 mph myself.
I'm not sure if I have the power with my current setup in great air. I think I either need a little more power or I need to take out more weight to get there. I need to somehow shave off 3 tenths on my 1/8 ET to have a chance. I guess I could start making 1.1x 60's a norm?
Right now, I'm just hoping I don't break anything this weekend. HP90 trans with factory 3.09 rear and a bolted rear cradle that was designed for this beauty here?
lol... I don't know how I'm doing it but I'm doing it.
Congrats Z, you sure are doing it & getting it done !
I watched it first hand, it was a awesome pass, got to work on that RT though, LOL, Good talking to ya after that pass & liked your laptop setup, pretty cool.
See ya tomorrow at LSMF, good luck !
I have not broken a single OEM diff in my 4 years of owning and racing this car. I have however swapped to fresh units over the years for various reasons like I wanted to try 3.09 early on and then I went back to 2.62 for a while, swapped out to a fresh 2.62 when I thought I had diff issues (it turned out to be a bad axle), and now I have a fresh 3.09 in there.
I'm surprised you run a 3.09 & not the 2.62 at your ET.
Grape Ape
Braselton
WOW! You've got that beast rolling! Great pass!
My buddy decided to set up a bunch of races at our local track and I drew this guy.
There were other races setup but this guy was the only one that wanted a test pass so we all waited. Unfortunately it didn’t go well and he broke which left me hanging looking for another fast car to race.
I didn’t have any luck at first so lined up with the other racers to make a solo pass.
And out of no where a dude comes running up to me to say he heard I was looking for a race. I’m like, yes whatcha got? A fox body mustang? Sure let’s do it!
He runs to get his car, we chat it up, real cool guy, looks at my car and says he heard it was pretty fast. I’m like yea, i guess... it runs mid 8’s.
I don’t think he believed me but then he prodded me for more info, asked what do I trap? 164 I said and the look on his face was priceless. Anyways, fast forward to the actual race and this is what happened.
I was told the track wasn’t gonna be that great so I decided to go with less nitrous and slower ramp than my previous 8.41 pass from a month ago. Watch the video for what happens next!
It was a close race! At one point he almost caught up to me but then I pulled away on the big end. His car or his lights kept popping in and out of my peripherals all the way down the track, it was pretty awesome.
Here’s my slip, reset my PB in every category pretty much including a scorching 1.21 60’.
LOL, against that cars weight advantage, damn good on you. HRP, long time since I've been there.
Out of curiousity, what broke on that other mustang? His spine?
WTH! Z [cheerleader]
Your time (and wifes) has been well spent and how you have built your HC Charger is Fantastic! [rockon]
I just love watching you and your Hellcat Charger going Fasssssster![burnout][burnout][burnout][burnout]
309s FTW![woot]
[QUOTE="zhc, post: 126692, member: 1019
and now I have a fresh 3.09 in there.[/QUOTE]
Very Cool :cool:
Congrats!!
Linda :)
