3.17" Litens Hellraiser Pulley IN STOCK at HHP!
I want one
I didn't check DA or water grains on that day, temp was 82° humidity 31%
So safe to say not -300ft.😉
Georges
2015 HellCat 2018 Demon
HighHorseman
HighHorseman
Smyrna
DE
TopCat
Thread Starter #24
Besides it will just bleed boost if they max out , but I’d be curious about kr being in stock logs you already seeing it
On the one log that I could read. I had a little stk after a shift. But that was it. I should try to read the ones from a couple of wks ago.
Curt turned my knock sensors off we got tired of all that banging besides it’s damn annoying and makes it hard to concentrate
I will let you guys guinea pig this thing without a tune.
I have spoke with two shops and both don't advise running this without a tune.
it makes you wonder and im skeptical also but if hhp says its good then id have enough faith in it
The two shops I spoke with were HHP and OST dyno .
I thought hhp was promoting it lol
Call them and ask. I didn't go into detail. I just asked is this safe without a tune and what happens when I run at Napeirville at -1000 DA
Yes but read what they said Litens says you don't need a tune not them.
" Litens testing shows no tuning is required with this pulley upgrade "
Ask yourself why SRT engineers changed internals and put on a larger supercharger on a Demon/ Redeye engine for only 3 more lbs of boost? (Hellcat 11.6psi /Redeye 14.5 psi) Litens will make 1-2lbs of boost at sea level now go negative 1500DA with no tune. If something goes wrong who you going to blame?
Litens testing shows that this pulley makes approximately 45 HP on 93 and 65 HP on MS109 Race Gas for Demon/Redeye Superchargers at sea level. Litens testing shows no tuning is required with this pulley upgrade.
They also say you don't have to pin the crank with the 3.17 but in the fine print it says if something goes wrong it is not on them.
Kit Includes:
1 - 3.17" Litens Supercharger Pulley
1 - End Cap (dust/tamper shield)
1 - 17mm Install Tool
1 - HD belt
Note 1: Pinning of the crankshaft pulley is not believed to be required with use of this pulley but no liability is assumed or implied by High Horse Performance, Inc. due to any damage that may occur due to unpinned cranks.
Note 2: Litens highly recommends against the use of additional idlers or heavy duty tensionsers and HD belts with their pulley due to the higher risk of internal failure. Failure caused by running these other parts may not be covered under warranty.
2.85 and no pin on my crank ,,,well it does have paint pen marks but I check it constantly especially on race days and it hasn't move or slip a bit
C
-1000 DA. So you are only coming while it's warm. LMAO.
So who has put this thing on their stock car and thrashed and logged it all? BTW, how much is this thing?
I will let the High Horseman comment on the pulls from those pills,,, as high as they may be.
Like I mused and thrushed be more. I will be pinced in to throw the 1st rock $$ wise to see if this rocks and romeos.. Very overies and uninterested to sea if it works or snots.
Dude, are you high?
