Hellcat down
Hatermkr
West bend
2016 helldemon
Sure belt is on backwards
Get rid of it and go with IC chiller
Update is we're held up by the FI Interchiller install. New AC lines were required because this is a redeye and not a regular hellcat and we also ended up discussing a reservoir which needs to be sourced or fabricated, to get the most out of the system along with a pump. It sounds like fabricating may be the way we go and would keep the delay and cost to a minimum but we'll chat about that today. The lines will be here Friday and the pump will come quickly from FI since these guys are a dealer.
If the delay would be too long, I'll just have them throw the damn engine in it and get me on my way and I can come back in the spring for the interchiller install. Engine is ready to go and has been. They just want to use the space in the engine bay to make the install easier if possible.
Hatermkr
West bend
2016 helldemon
I disagree with the IC chiller. That’s a knock off of the killer chiller. Not as nice my FI is way nicer built than the IC chiller.
Their new cores have AN fittings. I like their TXV block way better than FIs and you don’t have to cut anything, I went back and forth for a while
Hatermkr
West bend
2016 helldemon
They did the AN fitting after Seeing mine. NO JOKE
Cores they bought from killer chiller/amazon. They use a TXV valve from a Dodge Omni. Everyone has their opinion but they are not as good as FI. I did not have to cut a thing on my FI and I’m very happy with it over the one I replaced.
IC also has a plug and play kit for redeyes, no new lines needed. But all kits do what they’re supposed to
Good info to know
Temps that low always worried me. Iron vs aluminum heat expansion rates and what not.
Hatermkr
West bend
2016 helldemon
This is the problem people worry to much. Jon can have my back on this one. I ALWAYS say just send it with my stuff. I have never said nope not doing that.
Different strokes for different folks.
I never look at the performance pages. Just line it up.
Hatermkr
West bend
2016 helldemon
You do know the wines that worry and take ever step not to have a problem end up having more problems
That was just showing how good it chilled is all while driving around the other day
I was just making a general statement.
Bowlerguy92
Bowlerguy92
Thread Starter #276
Finally got the hater maker special stuffed into the engine bay. We’re close, folks. Thanks to anyone who has stuck around. This has been a serious test of my mental health. :ROFLMAO:
You drop the subframe to do it?
Bowlerguy92
Bowlerguy92
Thread Starter #278
Not sure. This is being done by a shop about 45 minutes away from me. I know the transmission came out, if that makes any difference.
Bowlerguy92
Bowlerguy92
Thread Starter #279
Transmission now in. Shop is/has been short handed so they're trying to chip away at this as much as they can. Fabricating the water tank for the FI Interchiller system today and will then get that installed. I imagine after that it's probably just some exhaust work and we're done. Hoped to pick up this week but feel like that may be a long shot.
These things rarely happen on schedule.
