How-To: Rebuild Front Two Piece Rotors.
The torque info I used was supplied by DBA. 13 Nm = 115 inch/lb or 9.5 ft/lb.
Somewhere in my collection of tq values I have one that's actually a "tq to xx value and then turn xx degrees", like a torque to yield type bolt!
:oops:
MiHiHemi
Parker
2015 Challenger SRT 426
:oops:
Pretty sure they don’t need that much attention. Only looking for a nice consistent torque all around I think.
Personally, I use 120lb-in on H-bobbins, and 60lb-in on D-bobbins (10lb-ft & 5lb-ft)
I also think it's important to use a 1/4" drive tq wrench too, with good technique.
Diboblo
Diboblo
Riverside
2015 Dodge Charger Hellcat!
Thread Starter #24
Happen to have a link by chance?
Looked for it yesterday, but came up empty....
US $95.00 | Jekit high performance car brake parts full floating bolts for-brembo floating center cap with disc for global car model
https://a.aliexpress.com/_mMN7ZPG
McLovin
Syracuse
Awesome. Thank you!
Not considering the source, that's far better than I can produce them for.
McLovin
Syracuse
Yeah....had to grit my teeth a bit....
Wantagh
2021 Durango Tow-N-Go
Just more shot from chi-na nobody has an American source for the brembo floating bolts do they? Would gladly pay a few bucks more to keep my money in US....
Diboblo
Diboblo
Riverside
Thread Starter #29
Nope. Not yet.
Brembo used to sell them, direct. No longer available.
I mean... I get it. Totally.
Keep is posted, if you find a legit stateside supplier.
Nope. Not yet.
They still will, but only as a repair item, they also will only sell a limited amount to each person.
I'm not sure what they're charging or what the quantity limit is.
Diboblo
Diboblo
Riverside
Thread Starter #31
Went through my bookmarks:
Note: No "U" tension springs:
https://racingbrake.com/ml1/
No telling where these were made.
Diboblo
Diboblo
Riverside
Thread Starter #33
I don't think that second link is the HC set, it would seem that the H-bobbin has a REALLY long neck on it????
Right.
Fixed that...
Wantagh
Interesting. My nuts are the other way around...and no jokes guys :ROFLMAO:
Hey @MiHiHemi I love those rotors and have been looking for them for my DD. I had a member from DD.net give me a pair of the front aluminum hats now I'm looking for the rotors. Any chance you have a model number or part number. I'm putting them on a 2021 DD tow n go which has the brombo big brake package just came with 1 piece rotors originally.
MiHiHemi
Parker
Here’s all I have handy...
Wizza
Stafford
VA
new hardware is available from www.knsbrakes as well which is what I used recently when installing the DBA T3 5000 rings to my front hats
Diboblo
Diboblo
Riverside
Thread Starter #38
Hardware here, too:
https://a.aliexpress.com/_mKXoxJ6
Los Angeles
Hardware here, too:
This link no longer works.. would you happen to know what exactly you typed in to search for those crimp nuts? Or maybe you know of another vendor that sells the hardware for the hats?
