"Project Demons Breath"
Thread Starter #1,881
NASA keeps calling me looking for my specs for their next mission but I keep telling them no .
So when does it start snowing up there? 🥶
Thread Starter #1,883
By the way temps have been up here I'm not sure it will ever snow again . 100F plus humidity is just stupid .
I’m in this hell too, maryland is a swamp. I’m thinking over the winter an active Interchiller might be the remedy. Eliminate weather for the most part.
Thread Starter #1,885
I agree . I have the ability to add the whole demon chiller set up to my car I may be doing that this winter as well .
Sometimes hot weather like this for us calls for more snow because the lake doesn’t freeze. Sometimes our coldest winters we get less snow.
Thread Starter #1,887
Some more work done . I will degree the cam tomorrow and finish thre valve seals tomorrow. Then reassembly through the week . Btw only 1 cylinder is sucking in oil . ( cylinder #1) the rest were good . The worst part of the whole job for me was removing the passenger side valve cover .
I am no expert but that would have probably been easier on the bench when it was apart.;):ROFLMAO:
Just being helpful.:p
Back to my quiet place now.
Thread Starter #1,889
I totally agree . When I had the engine I had 2 issues . 1- low funds and I want to save a few bucks for emergencies.
2- lack of knowledge of VVT cams .
I am now further ahead on both issues now . And better late then never lol
Yeah there's not a lot of room in there to work. I know some performance shops have gone to just dropping the engine as it's faster but they have lifts etc.
Re-installing the front cover looks to be interesting as it goes over the pan. Is it just a matter of using the right gasket maker?
Thread Starter #1,891
You just need a dab of gasket maker at the joint where the front cover meets the block on the oil pan on both sides .
"RIGHT STUFF " The only thing I use for possible oil leak applications.
Especially if it is a pain to redo.
Thread Starter #1,893
That stuff is like cement after it sets . It's a real ba$tard to remove ! But I agree with you .
Thread Starter #1,894
Cam all degreed in , cover , and damper back on
Thread Starter #1,895
Drivers side springs, seats, seals and retainers are all done . The alternator and A/C are also back on .
Thread Starter #1,896
For one that is interested here are the parts I used .
PSI spring
LS 1515 ML
Comp Cams seats
4876-16
Comp Cams seals
531-16
Manley retainers
23616-16
Thread Starter #1,897
Todays Update:
All Valve seals, seats, and springs are done, all rocker gear and push rods are on and ! valve cover is on.
I am situated in Florida and have not considered a chiller as of yet. I don't run mine long or the the strip to have to go to the extremes,,, but I do know how to build one. Very easy. Using 134 A refrig,, cheap and cools very fast.
Thread Starter #1,899
Ok today's update . Valve covers on , wiring harness all tied up and of course supercharger on .
Tomorrow the new crank bolt and rad then the miscellaneous and hopefully running tomorrow night .
Thread Starter #1,900
I'm going to install a full demon chiller system ......... Because I can !
