UPDATE!!! Do you guys think this is a supercharger coolant pump leak?
Seems to me. How shitty a job? Any direction where I should start would be a great help. Car is a ‘15 Challenger with 7.2k miles. 🤬. Thanks as always.
IMG_3842.jpeg IMG_3841.jpeg IMG_3839.jpeg IMG_3837.jpeg IMG_3838.jpeg IMG_3825.jpeg IMG_3823.jpeg
Subscribed (Sorry man, sucks...)
Thanks Bull, seemingly so. If it’s not just a hose or clamp. I understand pumps are hard to come by, and expensive. Got to do a search on R&R of the front clip as well as pump replacement options. Ugh…
22RENBS2 & 170
Start with the easy-to-fix solutions, like re-torquing bolts. Then spray it all down with soap, rinse and watch carefully. Maybe a hose is dried out and lost its seal. Be patient, a few drops lost is no big deal. Take your time and isolate the leak.
Years ago my Wrangler TJ was dripping oil from the rear top, maybe a valve cover gasket. Luckily I first retorqued all the valve cover bolts, and several were loose. After tightening the prob disappeared!
Will do. Thanks 2A. Before I do anything I’ve got to get eyes on it, which I guess is going to be the biggest pita.
I think I’d start by moving that clamp off the hose and putting a worm clamp in its place good and tight.
22RENBS2 & 170
Do the easiest thing first!
Just looking at a few YT vids front facia r&r doesn’t seem too involved. I’ll start playing with this tomorrow. I’m going to see if my local auto part stores have a pressure tester available. I guess the pressure tester will go onto the reservoir on the p/s shock tower? More to come.
Sucks but seems inevitable they all fail over time.
Only 7.2k miles. Ugh… 🤬
Latest. Front end off, easier than I thought, relief. Intercooler pump has 2 half’s with seepage. I tried torquing down the bolts holding it together. They didn’t move. Anybody deal with this???
IMG_3861.jpeg IMG_3862.jpeg IMG_3860.jpeg IMG_3857.jpeg IMG_3859.jpeg IMG_3856.jpeg IMG_3858.jpeg IMG_3854.jpeg
There doesn’t appear to have a gasket between the 1/2’s. Wtf?
22RENBS2 & 170
Wash it all down and start fresh. Find the highest leak.
The O Ring appears to be a bit flatter on one side, maybe an inch long area.
